Old 08-23-2012, 06:18 PM
RdHuggr68 RdHuggr68 is offline
Default LS1 fuel starvation problem??
I have a 2nd gen Camaro with a 2002 LS1 and spectra fuel tank with a Walboro fuel pump. The problem is when I go around a sharp turn accelerating through the turn it acts as though it is not getting any fuel even with the tank almost full. I have to take my foot off of the gas pedal to get it going again.Could this be anything other than the fuel tank or pump? I know this probably isn't the best tank available but it was in the car when I bought it.
Thanks, Kevin
Old 08-23-2012, 10:44 PM
Vince@Meanstreets's Avatar
spectra pickup?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-25-2012, 05:23 PM
I am not sure, what pickup is in there, I assume your saying that the Spectra pickup is a POS?
Kevin
Old 08-25-2012, 06:31 PM
dhutton dhutton is offline
Kevin
Yep, pretty much. Although this is the first I have heard of one that doesn't work well when almost full.
Don
Old 08-25-2012, 07:01 PM
CarlC CarlC is offline
Almost full? How many gallons are in the tank when it happens?
http:www.vaporworx.com
Old 08-25-2012, 08:14 PM
ccracin's Avatar
ccracin ccracin is offline
OP, you just happen to have the resident expert on fuel systems jumping in here. Carl will help you out for sure!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 08-25-2012, 09:23 PM
I probably had close to 3/4 of a tank of fuel in it when it started acting up. i am going to fill the tank tommmorow and take it out and I will post my results.
Thanks Kevin
Old 08-25-2012, 09:25 PM
Thanks Kevin
I am not sure of the capacity of the tank, probably 16 or 18 gal.
Old 08-26-2012, 06:24 PM
Well I headed to the gas station and just slight turns under acceleration and it was starving for fuel. It took 8 gallons and I tried some turns and it never hesitated. So what do you think? Get rid of the spectra tank or get a better fuel pickup? Any suggestions would be appreciated!
Kevin
Old 08-26-2012, 07:43 PM
get a better pick up, something more than a tube. See if Carl knows of a retrofit sock or bladder screen.
Dealer for
NEVER FORGET -11
