Closed Thread
Old 08-23-2012, 07:08 PM
camcojb camcojb is offline
Default Fesler Built 1972 Chevy Nova "Project Julia" just announced for sale
I'm listing this ad for a good friend of mine. I've known him for several years, and he's a straight shooter. This car is VERY nice. Please contact Bryan for any additional questions, his contact info is below. As per Bryan:
__________________________________________________ ___________
I've decided to sell my beautiful 1972 Pro Touring Chevy Nova "Julia". It was built from the ground up for the seller by the guys at Fesler Productions in Scottsdale Arizona. Feel free to hit me up with any questions at [email protected] or call (text) me at 520-399-7807 for more details.
The car is in perfect condition, garaged since the build up, and the last show was in Vegas for Ron Francis Wiring. With around a 550HP Z06 motor, air suspension, and full custom black leather interior this ride is a steal at this price.
Appraised: $200k+
Price: $130k
Press: Chevy High Performance cover car and chosen "Top 12" of 2010
CHP URL: http://www.chevyhiperformance.com/fe...72_chevy_nova/
KEY FEATURES
MAKE: Chevy
MODEL: Nova
YEAR: 1972
COLOR: Nissan Sporty Silver Metallic
MILEAGE: 2,100 (since build up)
ENGINE: 427 cu. in. LS7 motor (approx. 550HP)
TRANSMISSION: GM Performance 4L65-E transmission
CHASSIS/SUBFRAME: Chris Alston
REAR DIFF: Currie 9″ rear end, Currie 4:11 gears,
OTHER DETAILS:
Custom filled chrome front bumper,
Front bumper brackets modified to fit closer to body,
Stock grille,
Stock grille shell,
Fesler halogen headlights,
Stock turn signals,
BeCool Aluminum radiator,
Stock radiator support,
BeCool transmission cooler integrated radiator Spal electric fan,
Custom fabricated aluminum fan shroud,
Custom fabricated air duct,
Earl’s hose fittings,
Stainless Steel overflow tube,
Painted to match LS7 engine covers w/custom Nova SS billet inserts,
Aluminum heads,
Aluminum block,
Billet Specialties billet aluminum water pump,
GM performance stand alone fuel injection system,
Stainless steel fuel lines,
Holley fuel regulator,
Billet aluminum pulleys,
Billet Specialties breathers,
Walbro fuel pump,
GM Performance plug wires,
AirRaid air cleaner,
Vintage Air air conditioning compressor,
Tuff Stuff 130 amp alternator,
Billet aluminum accessory brackets,
Detroit Speed power steering reservoir,
Serpentine accessory belt,
Billet Specialties steering system,
Vintage Air air conditioning dryer,
Flush inner fenders,filled all holes,
Hooker headers,
GM Performance Hi-torque starter,
Stainless steel brake lines,
Earl’s line fittings,
Chassis Works adjustable A-arms,
Chassis Works front suspension,
Chassis Works spindles,
Chassis Works front sway bar,
Shock Wave front air bags,
Chassis Works front clip,
Stock stainless steel bolts and fasteners,
Wilwood vented front disc brakes,
Wilwood calipers, 4 piston rear, 6 piston front Slotted and drilled rotors,
Smoothed firewall,
Goodmark cowl induction hood,
Fesler billet hood hinges and springs with S/S lift supports
Hydratech dual reservoir brake booster,
Tinted glass,
Smoothed & filled body,
Shaved roof molding,
Ron Francis wiring system,
Leather wrapped dash trim,
Stock under dash panel,
Vintage Air air conditioning outlets,
Custom fabricated instrument cluster,
Auto Meter gauge set,
Auto Meter tachometer,
Dakota Digital air ride control panel,
Vintage Air air conditioning control panel,
Billet Specialties tilt steering column,
Custom fabricated steering column drop bracket,
Fesler billet aluminum steering wheel,
Electric Life power windows,
Billet aluminum knobs & controls,
Pioneer am/fm / CD / head unit,
DVD Recaro leather upholstered front seats,
Leather upholstered matching rear seat, Suede headliner, Suede visors,
Custom fabricated center console,
Custom fabricated arm rest,
Padded leather trimmed door panels,
Lokar door pulls,
Suede rear shelf,
Custom stitched carpets,
Fesler floor mats,
Dynamat sound insulation,
Powder coated black rocker trim,
Julianno’s seat belts,
Lokar pedals,
Custom fit car shifter,
Wilwood parking brake,
Fesler 3 piece custom wheels 19×19.5 front 19×11,5 rear Michelin tires,
Accuair onboard air suspension tank,
Viair 400C onboard air suspension compressor,
Custom S/S & Jet Hot coated exhaust system,
Custom fabricated rear four link / suspension,
Chassis Works adjustable rear air bags,
Custom fabricated frame connectors,
Custom fabricated rear suspension,
Flaming River Shafts & U-joints Wilwood rear disc brakes,
Wilwood rear calipers,
Wilwood 14″ rear rotors,
Custom gas tank,
Walbro fuel pump,
Holley fuel filter,
Custom fabricated mini tubs,
Custom engineered rear sub frame,
Custom upholstered trunk,
Custom carpeted trunk,
Kicker trunk mounted amplifier,
Trunk mounted Optima battery with Billet Specialties hold down,
Fesler Custom rear lights,
Custom Meg’s exhaust tips,
Fesler billet aluminum trunk hinges,
Stainless steel trunk strut support,
Custom fabricated rear bumper,notched for exhaust tips,
Custom fabricated rear bumper brackets, to fit closer to body,
Custom Show quality Silver exterior paint.
Old 08-24-2012, 05:46 AM
coolwelder62's Avatar
Beauitful Nova,GLWS.
Old 08-25-2012, 05:36 PM
NOVA NOVA is offline
Question 70 or 72 ?
Just curious, the ad says 72, the video below says 70
Forgelines - Ridetech - DSE Tubs - ZZ4/700R
Old 08-26-2012, 10:20 AM
The car is a 72, the video is mislabeled.
Old 08-27-2012, 06:23 PM
som1969 som1969 is offline
just plain SEXY!
Old 08-28-2012, 04:00 PM
fesler's Avatar
fesler fesler is offline
This is one bad ass car and if you have any questions on the build please let me know. I will help answer anything you may need as we did the car from start to finish.
that rear tire is just so sick on this car 345/30ZR19
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 09-04-2012, 05:22 PM
tones2SS's Avatar
tones2SS tones2SS is offline
I remember this build. What a great car.
Old 09-11-2012, 12:50 PM
Thanks for offering to answer questions.
Old 09-11-2012, 02:13 PM
fesler's Avatar
I am surprised no one is intersted in this car its a killer deal. I have a guy that wants to buy it but has to sell his truck first.
Chris Fesler
Old 09-18-2012, 12:13 PM
MHORTON79 MHORTON79 is offline
This car is awesome. I remember this one.
Closed Thread
