Old 08-25-2012, 01:23 PM
v8s10kid's Avatar
v8s10kid v8s10kid is offline
Default clutch problems
its a 305 v8, muncie 4 speed, stock replacment clutch, with a "racing" throwout bearing.
the clutch is draging just enoungh so when i have the pedal all the way down the input shaft still spins and it cant go into reverse. but if i put it in 1st then reverse its fine.
i didnt do the swap. the mechanic that replaced the throwout bearing last year said its a "race part" and wount last long yet he replaced it with the same part and not a stock style one.
i was also told its not a muncie bellhousing so he had to cut the flywheel to get the spacing right.
i think its the master cylinder, it has about 1 to 1.5 inches of play. what do you guys think?
1984 v8 s10 - teal, short wheelbase, 15 inch rally wheels, 305 h.o. , muncie m22, dual super 40's, much more (daily driver)
1998 ford escort - enduro race car, 2.0 sohc, auto, only driven to church on sunday
