Old 08-27-2012, 02:39 PM
Moparigno Moparigno is offline
Default Z06 rear wheel hubs
Hi,
I would need to get a set of OEM Z06 hubs for a custom suspension setup.
It seems that there are 5 different parts related to the rear hub and bearing assembly: FE1, FE2, FE3, FE4, FE5.
The last one costs more than twice the first one.
Do you know what is the difference between them ?
Thks.
Paolo from Italy:
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383
'65 Shelby Cobra 427 Replica
Old 08-28-2012, 12:12 PM
Apogee Apogee is offline
The FE* numbers are RPO codes: http://www.corvette-web-central.com/...teRPOCode.html
I believe the FE5 belongs to the ZR1 Corvette with the J57 carbon/ceramic brake code, hence those being twice the price. They're the heavy-duty unitized hub assemblies designed specifically for the ZR1 application.
All of the hubs should be interchangeable from 1997-2008...then it gets a bit more complicated with the introduction of the ZR1 as noted.
Tobin
KORE3
www.kore3.com
