Old 03-14-2006, 01:26 PM
CAMAROBOY69 CAMAROBOY69 is offline
Default Questions about DC Controller
I tried contacting Jabin yesterday and today via e-mail with no luck. So I figured I would post in the next best place.
I have a few pics and want to verify any confusion so I hook this up correctly.
Questions
1. Is the little black think on the left the jumper?
2. Does that go vertical or horizontal across the pins? I assume vertical because it has 3 connections.
3. There is something attached to the lower left screw. Is the black thing the surge protector?
4. Does it look like I have the blue plug hooked up correctly on the 1,2 pins?
I am going in the garage within a couple hours to install this and want to make sure im in the right direction.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
Old 03-15-2006, 01:04 PM
I just got off the phone with Jabin and he gave me all the answers I needed. We also learned that my current relay is fried. When my car got hot I would get something called "run on". This means my car would stay running when I turned off the ignition. The relay was soo hot it was fusing together causing the majority of my problems. He is sending me a new surge protector. The surge protector keeps the dc controller at 12v. The grey cable is a fusible link like gchandler said. It also sais right on the wire. He said I can hook fusible link and the dc controller power source right to the junction block as long as the block is 12.3-12.4 volts. If it is 14volts I cant hook to it. I learned a lot in 15 minutes. I need to buy something to test the volts to make sure. I currently have nothing to check that. He also said that the dc controller will automatically turn the fan on when the temperature in the radiator is 180* NOT THE ENGINE TEMPERATURE. This is where everyone gets confused. If I start my engine and my temperature gauge sais 200* then I need to add the jumpers to lower the temperature. Very very cool little system. Cant wait until my surge protector arrrives so I can hook this up and ditch the crappy relay.
Now that this thread is answered it can be placed into the cooling thread.
ILLUSION Website
