Old 08-28-2012, 08:22 AM
Mean 69 Mean 69 is offline
Default Protecting Body Paint from Weld and Grind Sparks
After changing directions "slightly" halfway through a build, I find myself needing to protect a new paint job from some additional work that I will be performing. Specifically, I will be tubbing a car, and also installing a custom roll bar. So, things will get a bit dirty, and also there is a decent chance of weld sparks from my MIG getting onto the body.
I have heard that there are products out there that are desgined specificlaly for this, i.e. won't allow a weld spark to melt through to the paint, but don't know where to find them. Direct experience and advise welcome.
Thanks!
Mark
Old 08-28-2012, 08:39 AM
LSX67 LSX67 is offline
3M makes a welding and spark deflection paper, part number 05916. You should be able to pick it up at your local automotive paint and body supplier.
Hope this helps,
Mike
Old 08-28-2012, 09:25 AM
dhutton dhutton is offline
The 3M paper is expensive but is the only thing I am aware of. Check prices on Ebay and Amazon. TCP Global also sells it online. It comes in boxes of 2 rolls. Some places will sell you 1 roll.
Don
Old 08-28-2012, 09:50 AM
Rick D's Avatar
Rick D Rick D is offline
Here the info from the 3m site
3M™ Welding and Spark Deflection Paper is a flame-retardant, repositionable, adhesive-backed paper product used to protect vertical surfaces from damage caused by welding spatter and grinding sparks. It is designed for use on vertical surfaces, such as:
automotive glass
painted sheet metal
automotive light fixtures
and many other vertical surfaces
The product is not designed for installation on horizontal surfaces, such as roofs, decklids, hoods, carpeting on floorboards. It is not designed to prevent heat transfer from sparks or spatter that are allowed to sit in one position on the paper, these will burn through. If the surface is horizontal, has areas where sparks could catch and burn, or if there are any other questions about whether this product is appropriate, it is better to use 3M™ High Performance Welding Drape (PN 05919).
Additional Product Information
3M Part Number 05916
UPC 00051131059160
Case Quantity 2 rolls per case
Case Inner Pack 1 roll
Rick
Old 08-28-2012, 11:28 AM
Awesome, that's the info I was looking for. Should have known 3M would have something, what "don't" they make?! Their thin "Green Corp" cutoff wheels are the best I have ever used, if not very expensive, but the only ones I will buy now.
Thanks guys, good info on the horizontal surfaces too, darned good point.
Mark
Old 08-28-2012, 10:12 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
A lot of pro bodymen use something like this: http://www.eastwood.com/fiberglass-w...4ft-x-5ft.html as they never do complete repaints and it's re-usable.
Erik
69 Camaro
Old 08-29-2012, 12:10 AM
youthpastor's Avatar
automotive glass
painted sheet metal
UPC 00051131059160
I love this stuff- well worth the money- even if you save $$ from destroying 1 piece of glass
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 08-29-2012, 12:22 PM
I just replaced the windshield in my brother in laws Camaro -- a brand new one replaced with a brand new one -- because I ruined it with cutoff wheel grinding sparks while cutting the floors out....
I should have used some protection....
Old 08-29-2012, 02:24 PM
67goatman455 67goatman455 is offline
we have always used those at work, they are awesome! but being pretty heavy they dont like to stay on anything without something to hold it down. they have a version that is soft and typically black. the fiberglass ones are very stiff and make me think they scratch the paint esily
Old 08-31-2012, 09:04 PM
elitecustombody's Avatar
Harbor Freight has nice thick,heavy and yet very pliable fiberglass welding blankets,much cheaper than Eastwood
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
