Old 09-02-2012, 11:53 AM
protour73 protour73 is offline
Default Hey Tracy!! Is this a good carpet choice?
Tracy, you are the resident interior guru here, you've been doing it for years and the interiors you guys turn out are just unbelievable, so I called you out (Marty's suggestion).
I want to replace the stock looking loop carpeting in my '73 Camaro with a more modern cut pile type material.
I've found a source for "Camsal brand 9400 Series High Performance Luxury Cut-Pile" @ $34.95 a yard.
Your thoughts? Generally do you guys glue directly to the floor? I'd be going over Dynamat.
Specs:
Width: 72" Inches Wide
Weight: 40oz. per sq yard / 80oz. per linear yard
Content: 100% Polypropelene
Soft Latex Backing
Brushable
Stain Resistant
UV Treated: 120 hours UV Light Fastness
Fire Retardant: Meets MVSS-302
Mildew Resistant
Thanks!
Old 09-02-2012, 07:03 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Specs look fine, where are you getting it. Just want to know if its a good source. If it looks good it should work for you. The weight is a big factor with carpet to make a long lasting floor. We put a pad down over the Dynamat first then carpet . between the pad and Dynamat you get a very dead floor. Always the best way IMO. Use a 30 oz. jute pad.
TRACY WEAVER
www.recoveryroominteriors.com
Old 09-02-2012, 08:01 PM
http://www.yourautotrim.com
I've made many purchases from them, all my door panel material, the trunk project material, etc. Great folks to deal with and knowledgeable too.
...thanks for chiming in Tracy, always appreciate your opinion!!
Old 09-02-2012, 08:06 PM
Rick D's Avatar
Rick D Rick D is offline
Ok, now you are just looking for new projects to do!! Come on already just built another car
Ok don't let Cindy read that one
Rick
Old 09-04-2012, 07:47 PM
Supporting Vendor
That carpet should work just fine for you.
TRACY WEAVER
Old 12-02-2012, 05:24 AM
Tracy, do you generally use some type padding? or not necessary? would you advise against gluing directly to Dynamat?
Just trying to get all necessary info before tackling this
Old 12-02-2012, 08:46 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Guys, thanks for this thread. I was wondering were to get some nice, luxury carpet for my Chevelle.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Supporting Vendor
Scott, call the shop, Its easier to get the message across on the phone than typing..LOL 402 235 3800. Ill get you steered in the right direction, Pad should be used to make the floor look better and help with sound.
TRACY WEAVER
