Old 09-10-2012, 08:50 PM
73camarols1 73camarols1 is offline
Default DSE battery cables
I was looking at some DSE pics and I was just wondering why they run the neg battery cable all the way to the front with the pos cable? I see a lot of other relocation kits only come with a short piece of neg cable. Thanks Bill
Old 09-10-2012, 09:03 PM
brownz brownz is offline
From what I know you want to ground your car to multiple locations. So you want to grounf the engine, body ect to the battery so that they all have the same ground.
when I did the battery cables on my car I ran what DSE has but aldo ran one to the body in th trunk area and also on to the pass side cylinder head.
Hope that helps
Old 09-10-2012, 09:09 PM
You will get lots of opinions but I like the negative cable grounded to the drivetrain close to the starter instead of running through 40 year old sheet metal. A body to drivetrain strap is also recommended.
Old 09-10-2012, 09:24 PM
FETorino's Avatar
FETorino FETorino is offline
You and Herb Adams. Back in the 80s in his guide to making first gens handle he sold battery relo kits with full length cables for the -
Same reason you always see dim tailights on old cars, old sheetmetal often makes for a bad ground.
Rob in SoCal
Old 09-11-2012, 05:50 PM
Thanks guys. I know if DSE was doing it there was a good reason.
Old 09-11-2012, 09:56 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Also DSE uses 2AWG battery cables instead of 1/0 or 1AWG. Is there a reason for that also?
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 09-12-2012, 08:37 PM
IndyNova's Avatar
IndyNova IndyNova is offline
Prob because it's easier to work with, and there's not much difference in resistance in that short of length to warrant the additional cost and weight of 1/0 or 2/0. Just a guess though
Old 09-13-2012, 05:49 AM
72Z/28's Avatar
Thanks for your input man
72 Camaro RS:SOLD
68 Camaro:
Old 09-17-2012, 02:29 PM
Gandalf Gandalf is offline
While I cannot speak for DSE I can confirm all of those points. It is less expensive, lighter and you will REALLY appreciate how much easier it is to work with.
With that said, I will add: be sure to purchase quality cable with good insulation and the more strands of actual wire inside, the better (electrically and also more flexible). Be sure to use good grommets if passing through panels and use cable clamps to stop them from moving around.
As Todd suggested - I run a gnd cable forward also plus ran from that to the sub and another to the engine itself. I have one from the battery itself to the body in the trunk area also.
Hope that helps.
G.
The Following User Says Thank You to Gandalf For This Useful Post:
Ellis6 (01-03-2019)
