Old 09-26-2012, 02:08 PM
dirtymaro68 dirtymaro68 is offline
Default 70 Challenger front backspace and width info needed
Hows it going guys im trying to find out if anyone out there knows what back space and width I need for the front wheels getting ready to get some forgelines for my 70 Challenger with 2 in. drop spindles and hotchkis suspension/ wilwood brakes. Any info will be greatly appreciated
Old 09-28-2012, 09:07 PM
millerman340's Avatar
millerman340 millerman340 is offline
I chopped mine up but I still have another car I can go measure for you...Dave
Old 09-29-2012, 12:03 PM
MoparCar MoparCar is offline
If you're running Hotchkis, call them up. Their yellow E-Max Challenger test car is the hot ticket and I'd think they would share specs for a stock width front suspension. They are a great company to deal with. They may also be running forgelines, but I'm not sure.
Wes
Old 09-30-2012, 06:23 PM
AUTODYNAMICS AUTODYNAMICS is offline
4 3/4 front b/s
Old 10-10-2012, 11:07 AM
Default Thanks!!
Originally Posted by AUTODYNAMICS View Post
4 3/4 front b/s
Thanks for the info. Do you pretty much have the same set up or know of someone that does? I got to get it right on the $ so it doesn't cost me more $ LOL. Thank you very much really appreciate it.
Old 11-25-2012, 07:10 PM
irishlsxer irishlsxer is offline
On a side note, I have a set of forgelines I guess I'm selling that I'm sure you would absolutely love since apparently you're in the market
Old 01-12-2013, 01:46 PM
hp2 hp2 is offline
4.75 is the max you can use with a 15" rim, and that may be a variable measurement since you now have drop spindles. In stock form, anything greater than 4.75" put the rim lip into the upper ball joint. With the drop spindles or a 17"+ rim, you can move to 5 or 5.25 backspace with an 8 inch wide rim. Of course, the more you pull them in, the greater the odds of rubbing the frame rail.
