Old 10-07-2012, 07:08 PM
funkyflynz funkyflynz is offline
Default Wilwood - manual or power
Im going to be running 13" rotors 6 piston front, and 12" 4 piston in the rear, will these be big enough to allow me to run manual brakes and not have to stand on the pedal too hard? - 3200lb car, mostly twisty roads.
Ive looked at running a hydra boost but it wont fit without some pretty major modifications, so i plan to run manual, i see a lot of guy here have manual brakes, but at the same time run some pretty big rotors too!
I do have the option of swapping the 13" for a 14" rotor on the front, but its likely i would have to change my wheel plans as the 18x8.5 Foose Nitrous wheel i have for the front run a "hidden" valve that i think will hit the caliper if i go 14" rotors.
So in short - are 13" rotors ok in a street car with manual brakes for hard and fast driving?
Old 10-07-2012, 07:33 PM
Flash68's Avatar
Flash68 Flash68 is offline
I ran 13"/6P front and 12"/P rear in a 3300# car with manual brakes and liked it a lot.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 10-07-2012, 09:45 PM
I also ran this set up and it was fine. Not anywhere factory car assist though.
Old 10-07-2012, 10:36 PM
Sieg's Avatar
Sieg Sieg is offline
I run Kore 3 C5 13" up front with 7/8" bore manual and HP Plus pads and prefer the feel of a manual master, in part to my motorcycle background. I run a 245/18 200tw front tire and can lock them at 40 mph or less if desired. Basically I have more brake than available traction.
