Old 10-09-2012, 01:25 PM
heynow14 heynow14 is offline
Default Afco adjusters with Landrum 8" springs?
Hey all -
'69 Camaro suspension redo is JUST ABOUT done. Ride height is now getting attention. I have Afco 9.5"h 600# springs and Afco adjusters installed. I helix-cut the adjusters and welded threaded rod...it all works very nicely. BUT even with the adjusters tightened up 100%, the car is about .5" too high. I read repeatedly that Afco adjusters would provide more than enough adjustment to handle anything but evidently not. After going through this process, I am not happy having no downward adjustability. Has anyone else had this experience with Afco springs + adjusters being too short? I read all of the good feedback but I've not heard about this problem before.
I found that Landrum has 8"h X 5"w springs in all popular rates. Based on the math, it appears that these will work. I ordered a pair and will install in the coming days.
Anyone use Landrum springs + adjusters with success?
Thx,
Nick
Old 10-09-2012, 01:37 PM
SR71 SR71 is offline
I used the afco adjusters and 8" springs in my very first pt suspension build. they worked well.
since I had aftermarket flat bottomed lower a-arms, I put the adjusters on the bottom for ease of adjustment. my car was VERY low so I ended up trimming a little off of the bottom of the adjusters to center the collar in the adjustment range at ride. this let me fine tune up or down as needed.
69 ss/rs clone, hugger orange w/wht stripes, 406/ 6spd/12 bolt drivetrain, ridetech tripples, speedtech torque arm, sc&c arms....centerline champ 506's and 275/335 kdw's
98 trans-am...black ram air convertable....firehawk bilstein suspension.
Old 10-09-2012, 01:53 PM
Cool...thx SR71. I'll get some pics posted once this is squared up.
