Old 10-16-2012, 09:17 PM
snappytravis's Avatar
Default Brake Lines Art morrison chassis
So I am about ready to start running brake lines on the 69 camaro, Just wondering on the morrison chassis if anyone has any advice. I would like to run it down the back edge of the crossmember but there are a few braces in the way, I though about running on the bottom side, but It may be easily damage there. What are everyones thoughts on the through frame fitting you can order through morrison? I would like to use a billet aluminum type clamp and drill and tap the frame for the clamps. I also am thinking about mounting the proportioning valve under the car out of site, what are the pros and cons of this? How about the t fitting that splits the lines for the left and right calipers. Plan to use 3/16 stainless tubing, what's a good flare tool? bender?, I know lots of questions Just don't want to do it twice, thanks for the advice
Travis
