Old 10-17-2012, 06:36 AM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Default Brake light switch with wilwood pedal box
Hi guy's
I am installing a wilwood pedal box, how have you set up the brake light switch?
Greg
Old 10-17-2012, 04:47 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I used brake pressure sensor solenoid. It was probably a $10 part. Just mount it in line, connect a couple wires and you're good to go.
Matt
Old 10-18-2012, 06:08 AM
Thanks Matt,
I will see what I can find.
Greg
