Old 10-19-2012, 07:28 PM
Mark Umfleet Mark Umfleet is offline
Default 5/8 aluminum fuel line
Has anyone used the 5/8 or -10 aluminum hard line instead of the stainless braided? Just looking for pros and cons. Thanks for any input.
Old 10-19-2012, 10:51 PM
intocarss's Avatar
I've heard it likes to crack
Old 10-19-2012, 11:14 PM
I've heard that it cracks when you flare it. Aero quip has a fitting that doesn't require a flare. Just looking for a cheaper alternative than the braided.
Old 10-20-2012, 12:48 AM
CrossRamRich's Avatar
CrossRamRich CrossRamRich is offline
We've had success with that line on "Project Flashpoint". We made the run with two pieces. Used tube nuts and 37 degree flares. Worked like a charm.
Rich Bermea
Road Touring Customs
Gilroy, CA
Old 10-20-2012, 07:22 AM
Did you warm the end before you flared? Do you remember what brand tubing it was?
Old 10-20-2012, 11:35 AM
The brand is Moroso, the tube nuts were XRP. I used an Imperial 37 degree flaring tool and believe it or not a conduit bender.
Rich Bermea
Gilroy, CA
Old 10-20-2012, 01:22 PM
Thanks. I appreciate the info.
Old 10-20-2012, 05:35 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Another option is stainless fuel line. Aluminum line might work for a race car, but it is poor choice for a street car.
Anyway, here is a thread on it, in the past. Just search on Bentfab. He can provide more input on what tools to use, etc.
https://lateral-g.net/forums/showthread.php4?t=28726
Old 10-20-2012, 07:31 PM
Just wanted to add that was 5/8 aluminum fuel line. Good luck with your project.
Rich Bermea
Gilroy, CA
Old 10-20-2012, 07:56 PM
Sparks67's Avatar
I saw his post, but it sounds like a street car. https://lateral-g.net/forums/showthread.php4?t=38376
Aluminum is bad idea on a street car. You can do regular hardline as well.
