Old 10-21-2012, 09:12 AM
joeljet joeljet is offline
Default suspension kits
alstons g-bar and vari-shocks or ride-tech with single adjustables? cant afford a torque-arm setup. it will be welded in with subframe connectors and solid bushings. plan on doing both front and rear on a 73 formula with an ls/t56. thanx joel
Old 10-21-2012, 10:43 PM
makoshark makoshark is offline
Ridetech all the way
Old 10-22-2012, 06:50 AM
coolwelder62's Avatar
Ride Tech I am a RideTech Customer and a Ride Tech dealer.The product's fit,Work very well,Great value for the money,Awesome customer Service,The Ride Tech coil over's are the best coil overs for the money.Kevin & I have tested Ride Tech,QA1's,Strange,Afco.And the Ride Tech coil over deliver's the best ride & control,Faster lap time's.
Old 11-08-2012, 10:04 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Joel,
I just saw your post so I apologize for not responding earlier. What is your intended use of the car? Expected power level?
Our g-Bar and g-Link systems are designed to bolt into the car using stock suspension mounting points to properly locate the system. Once it's bolted in place, there is only minor welding required to properly secure the system to the car. For your 73, we also offer the option of a new set of frame rails. They are custom bent to fit underneath the floor, allow more tire clearance, add a tremendous amount of strength and rigidity, and work with the stock fuel tank.
There is a lot of information about the g-Bar systems HERE and HERE and more info about all the options available for the second-gen Camaro/Firebird HERE.
Don't hesitate to call me, my extension is 247.
