This years GMR MEGABOWL will be located in two main booths, CPP and The BRAKE MAN!!!!!!
CPP – Booth #22979
New GMR front upright packages with CPP calipers and uprights. These packages feature the new CPP uprights along with C5 calipers backed up by a GMR selected brake package to complement our front bolt on C5/6 hubs. These packages are available for both AFX body cars and GEN2 F-bodies.
Brake Man – Booth #22832
The Brake Man and GMR have combined forces to bring to market top quality pro-touring and pro-street brake packages designed to work flawlessly with GMR products. GMR will be displaying an entire rear GMR9 STAINLESS 3.25 inch housing that will feature both the GMR pro-touring and pro-street rear full floater packages.
On Thursday and Friday GMR will be displaying the brand new GMR Fabricated C6 pro-spindle/MII upright with our C5/6 hubs and pro-street front brake package.
This new upright is hand fabricated with chromoly platework and designed to bolt into the pro-spindle / MII setups that are found throughout the industry. These uprights allow you to maintain the same WMS and convert all of your brakes to C5/6 packages. They will work with all aftermarket brake packages on GMR c5/6 hubs.
GMR - IN THE WORKS!!!!!
We have been insane busy so this is not 100% done yet but getting there….
The New GMR Corvette fabricated chromoly stock replacement upright. These uprights will be offerend in two different versions, one with all stock geometry and steering arms and the second with all stock geometry and no steering arms (for aftermarket suspension like IRONWORKS, DSE, MORRISON, and many more..) Eliminate Deflection and drastically improve the stiffness of your brake / hub package with these uprights. Weighing in at only 7.3 lbs these uprights are the perfect combination of strength and reduced weight.
This past year has been very busy and exciting with many new products and relationships. The GMR would like to take a second to thank the following people:
Jim R. of CPP - Thanks for all the help and your time / opportunity to showcase our new products with yours!
Warren / Cory of Brake Man - I cant say enough about these two, "knowledge" is the best word I can use to describe them. Thanks for all the time and effort put into our new packages!
Ray Hale - Thank you for being the one to spear head the new fabricated upright for the pro-spindle, and for being so patient with the design / built time!
Jason
