Old 10-29-2012, 09:40 AM
ghinmi's Avatar
ghinmi ghinmi is offline
Default Axle/differential for 1000 hp?
First post! I'm looking for some help on axle selection for my latest project. The part that throws everything for a loop is that it will make a little over 1000 hp at 3200 lbs and I will be drag racing it with slicks on occasion. The determining factor (in my mind) is differential selection. If it was a pure drag car I'd do a spool or locker with 35 spline axles but that would be less than ideal around corners. I'm having a hard time finding a good differential that can take the abuse and still be good around corners. I see that they make a 33 spline true-trac for the 12 bolt and a 35 spline s-trac for the 9", what is everyone's opinion on those? Any other suggestions?
Old 10-29-2012, 11:04 AM
NOPANTS68 NOPANTS68 is offline
From what I understand the new Wavetrac is supposed to hold that kind of power and be streetable. A buddy just got his for his 9 inch going into a full weight '68 Chevelle making 1250 RW. The Wavetrac folks insisted that it would take it all day long.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 10-29-2012, 01:11 PM
slow4dr's Avatar
slow4dr slow4dr is offline
The 35 spline set-ups with Platinum/Wave tracs are exactly what you need. You'll also want to upgrade the housing, pinion support and yoke as well.
-J
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 10-29-2012, 01:46 PM
Details on upgraded housing? I'm planning on 900-1000 with mine. I have the DSE rearend (9"). I'm ok with the previously mentioned upgrades. I'll see how long the 31 spline's last but I know they'll be changed eventually.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 10-29-2012, 01:55 PM
slow4dr's Avatar
Currie calls it their "Sportsman" case and it's Nodular iron with extra material in the right places. The pinion support and yoke they sell as an upgrade are billet.
Old 10-29-2012, 05:15 PM
69znc's Avatar
69znc 69znc is offline
Default The need
At 1000 hp and street driven there are many options. Dana, 9 inch... any major manufacturer can provide the needed components. First the question is what is rear wheel not engine dyno and then how much rubber can you run. 335 with tubed wells, axle is not the issue. Figure out how far you are going for tire fitment, how big of wells and what is the weight and work back from that. The HP is a singular dimension.
Old 10-29-2012, 09:16 PM
FETorino's Avatar
FETorino FETorino is offline
Default Give these guys a call
They build diffs for race cars.
http://www.dpiracingproducts.com/pro...1-2-tight.html
Rob in SoCal
Old 10-29-2012, 10:06 PM
intocarss's Avatar
I ran a 9" with 35 spline axles, a spool (total drag car) and the rear housing was braced. The car weighed 3018 w/driver and made 1000+ Hp, 1.20 60". Ran 14/32 slicks and never in 12 years did I see any signs of twisting an axle. BTW make sure the axles you get are streetable
Here's an intreresting chart on axles
http://qp.doonce.com/axle_tech.htm
Old 10-30-2012, 10:00 AM
ghinmi's Avatar
It should very conservatively make 1000 at the motor on pump gas. More if I get aggressive with it. AMC 426 stroker with an 83mm. Because it's a turbo car I will be launching off the transbrake on boost with a 28" slick at the strip.
I've been reading up on the Wavetrac, it sounds like the way to go. Any objections to the 33 spline for an 8.8? I've got an 8.8 in my other car and it would be nice to consolidate spare parts.
Old 10-31-2012, 05:31 PM
intocarss's Avatar
What size axles should you be running to be sure that you will not break one?
A simple formula can be used to help you find the absolute maximum torque your car can put to the ground. To find the maximum torque, take the (Torque of your car) x (Your first gear) x (Your rear end gear ratio) x (90% efficiency).
For example, let's say your racecar has 600ft.lbs. of torque, you have a powerglide transmission with a 1.86 first gear ratio, and you have a 4.88 gear in your rear end. When you put those numbers into the formula, you get the following:
600ft.lbs. (torque)
x 1.86 (first gear)
x4.88 (rear gear)
x.90 (efficiency)
4901 ft.lbs. of Torque
This is the maximum torque transmitted to both rear axles if the tires have perfect adhesion to the track, a and you launch the car at its torque peak.
The torque rating of Moser Custo Alloy Axles are as stated.
30 Splin- 6,200 ft.lbs. (per axle)
31 Splin- 7,000 ft.lbs. (per axle)
33 Splin- 8,200 ft.lbs. (per axle)
35 Splin- 9,600 ft.lbs. (per axle)
40 Splin- 12,000 ft.lbs. (per axle)
