Old 10-30-2012, 11:31 AM
MIKE@RIDETECH's Avatar
MIKE@RIDETECH MIKE@RIDETECH is offline
Default Ridetechs New Q Series Shocks
Thought Id post this up for those not attending SEMA. One of our new products is our Q series shock line. Here's a little info.
Nothing influences how your car rides and handles more than shock absorbers. If you could pick only one thing to change on your car to get the most overall improvement…upgrade the brains of your suspension…the shocks!
Ridetech’s new smooth body shocks are an important step in suspension technology. With its compact design, smooth body shocks were precisely developed to fit into a variety of stock shock locations, opening up Ridetech’s shock line to several new hot rod applications. This meaning builders can now upgrade their ride quality without reworking their entire suspension design.
Using the same monotube design as the ShockWave and Ridetech Coilover, new smooth body shocks are developed with a significantly larger piston. When compared to a twin tube design, the Ridetech monotube shock provides approximately 150% additional effective oil control surface area, giving it the advantage when damping suspension travel. In addition, the monotube design supplies a more efficient oil flow path that leads to cooler operating temperatures and consistent performance in extreme environments.
To develop the shock, Ridetech hooked up with Fox Racing Shocks, a brand who has had its hands in the bicycle, motorcycling, offroad, and military markets for over 35 years. Fox and RideTech both have had plenty of experience testing, developing and refining the entire ride quality and handling aspect of suspension design, so this shock not only fits…it works!
Old 01-31-2013, 04:49 PM
Streetrod77 Streetrod77 is offline
Will these shock also cover lowered applications? I see there will be a shock for the Comet. My Comet is lowered about 3 inches and the factory shock is barely sitting pass the spring.
Old 02-01-2013, 05:17 AM
Supporting Vendor
We have a lot of different stroke lengths for the Q series shocks. Just give us an installed height dimension and we can figure out what you need!
Skunk Werks
Ridetech
www.ridetech.com
