Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 11-02-2012, 09:02 PM
NOVA NOVA is online now
Arrow No longer need a motor
I am rebuilding mine so no longer need one, Thanks for the PM'S
Forgelines - Ridetech - DSE Tubs - ZZ4/700R
Old 11-02-2012, 11:51 PM
Vince@Meanstreets's Avatar
I have a running 350 carb to pan, its yours for free but you have to come get it. I can deliver for $400
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 11-03-2012, 03:19 PM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
Thats a pretty sweet offer!
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 11-04-2012, 01:29 AM
I have a feeling he might want something for free-er.
Dealer for
NEVER FORGET -11
Old 11-04-2012, 03:32 PM
Vince@MSperfab,
Thank you for the offer, very cool, the distance is a bit of a problem as I mention in my ad, and no I am not looking for anything free er a buddy also has been looking and called me but I cant get back in touch with him so I am kind of in hold pattern - thanks again for the offer, very cool
P.S I'll cancel the ad when I find something.
Old 11-05-2012, 11:56 AM
Jr's Avatar
Jr Jr is offline
How about this for a 350 crate motor purchased at Selman Chevrolet in Orange:
Specs on the motor:
Block: Cast iron, 2-bolt main, 1-piece rear main seal
Connecting Rods: Powdered Metal Connecting Rods
Pistons: Dished Hypereutectic
Compression Ratio: 9.4:1
Oil Pump: High-Volume Oil Pump
Timing Chain: Morse link-type
Camshaft: Flat Tappet Hydraulic (Lift .382" Int/.402" Exh; Duration @ .050" 165.9° Int/174.8° Exh; Lobe Separation Angle 111.9°)
Cylinder Heads: 65.3cc chambers, 1.94"/1.50" valves, swirl port intake design (heads are not performance-oriented; intended for good bottom end torque and fuel economy; intake runner is restrictive because it has a ramp cast into the bottom of the bowl to promote high swirl)
GM crate 350
2 bolt main
Quadrajet Carb ( the carb shop)
HEI Dizzy
New GM starter
Sanderson headers- the headers that will allow you to lay frame on a 67-72 chevy C-10.
assy drive with ac, alt, power steering, and water pump.
I have two different flywheels for this 350-1 for a turbo 350 and 1 for a 700r4
I bought this motor from GM. I may have put ONLY 200-300 miles on this motor. Also, I took this motor out for a LS 5.3.
This motor is a ready to run (turn key) motor.
I would like $2,100 for the complete setup.
I'm located in Yorba Linda, and will be more than happy to drop this motor off to you for no charge.
Old 11-06-2012, 10:24 AM
senor_Camaro senor_Camaro is offline
Default 350
I have one for 300 if you want to come check it out
SBC 350
268 XE comp cam
Roller rockers
Holley 650 DP carb
Weiand stealth
New harmonic balancer
Needs intake bolts and valve cover bolts, does nto come with accesories
im in Alhambra CA near Los Angeles 91803
