Old 11-03-2012, 07:36 AM
Mathi Mathi is offline
Default T-56 magnum with 2013 GT 500 engine
Hi guys,
Just one little question...
I have a Tremec T56-magnum transmission and I want it to use in combination with a new 2013 GT 500 engine. Is this possible?
Regards
Old 11-03-2012, 07:52 AM
wiedemab's Avatar
wiedemab wiedemab is offline
I'm fairly certain that this can be done. I know they make a longer tailshaft version of the T56 Magnum for the late model Mustangs, which I think has the same bellhousing bolt pattern as your GT500 engine would have.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 11-03-2012, 10:10 AM
Well, at this moment, I have a roush 427 R with that T-56 magnum transmission... So maybe with another bellhousing it would be possible?
Regards
Old 11-03-2012, 10:29 AM
wiedemab's Avatar
OK - some quick Google....................
Below is an excerpt from a popular Mustang site's ad for the T56 Magnum. Based on this, I'd say you just need the correct bellhousing.
Tremec T56 Magnum - - With the appropriate QuickTime Bellhousing, this transmission will bolt in behind your 5.0L or 5.8L small block as well as 4.6L or 5.4L modular motors
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 11-04-2012, 02:42 AM
ok, great! Thanks!
