Old 11-12-2012, 04:33 PM
b757jetdr's Avatar
b757jetdr b757jetdr is offline
Default Quick question on this third member!
Has anyone heard of this brand of third members? Yukon brand?
http://www.ebay.com/itm/9-Inch-Ford-...sories&vxp=mtr
This is a link to a eBay auction I found it on.
Chris K
Aircraft Mechanics: So pilots can have heros too!
Old 11-12-2012, 04:52 PM
Bryce Bryce is offline
I see them at SEMA every year. I dont know anyhting about them. Not sure where they are made.
Old 11-12-2012, 05:17 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I have heard of them. Lots of shops use Yukon gears to keep cost down on rear ends. Not a bad gear for a driver. Unless, you are going to be putting down some power, they're not a bad brand gears.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 11-12-2012, 05:42 PM
kp.touring kp.touring is offline
It's Randy Ring and Pinion's brand.
Old 11-13-2012, 06:11 AM
Ruslow Ruslow is offline
A pretty good case, the retaining lugs[for the side bearings] are better located to help in preventing cracking of the cap but then they made the cap with a step.Why? You will need to run that style of front pinion support,I don't think the standard pinion support will work.and think about what gear ratio you will running being aluim they had to add material and you may get interference with some of the bigger ratios.Stan
Old 11-13-2012, 07:06 AM
LS1-IROC's Avatar
LS1-IROC LS1-IROC is offline
Yukon makes good stuff.
Old 11-13-2012, 09:49 PM
intocarss's Avatar
I've heard good stuff about them
http://www.yukongear.com/
Old 11-13-2012, 09:50 PM
b757jetdr's Avatar
Thanks for the input guys, I am thinking about trying out this unit. I am going to try and do some more research on this though.
Chris K
Old 11-14-2012, 05:18 AM
Ringbrothers Ringbrothers is offline
I've used those guys and there really good to work with. Telly
