Old 11-14-2012, 10:05 PM
G's Chop Shop G's Chop Shop is offline
Default 6l80e swap into 68 chevy truck driveshaft?
I installed an LS3 out of a 2012 camaro into a 68 chevy pickup. Tranny has a 3 bolt mount with a dampner on the tail. What is the best way to go as far as a driveshaft?
Old 11-16-2012, 10:41 AM
INTMD8's Avatar
INTMD8 INTMD8 is offline
How long will it need to be? Might be better to make it 2 piece, then it won't matter that there is no slider on the trans as it would be on the back half of the driveshaft.
Old 11-19-2012, 04:44 PM
Steve Chryssos's Avatar
You can either have the trans disassembled and converted over to a 2wd pickup style unit with a traditional tailshaft (or sell it and get a 2wd pickup unit). Alternatively, you can set up crossmember that accepts a slip yoke style carrier bearing along with a 2 pc driveshaft. That might sound wonky, but any local driveshaft shop should be able to accommodate that solution. Also, the 2 pc driveshaft solution can sometimes help resolve pinion angle problems.
________________
Steve Chryssos
Ridetech.com
