Old 11-22-2012, 11:26 AM
Radlark's Avatar
Radlark Radlark is offline
Default 19669 Impala Sport Coupe
Real nice STRAIGHT car 350/350 car factory A/C car, I am the 2nd owner I purchased it from the original owner has the ORIGINAL pink slip the car is clean has 3 small rust areas 2 are the front fenders right behind the wheel (common and there are patch panels available for them) and the trunk area not the entire trunk area. New tires the car DOES run, I removed the gas tank to clean and replace fuel sender (tank is still out of the car) but can fire up for you, the car does have dual exhaust! The front bench is not with the car it was so badly weathered I got rid of it. The car does have factory DISC BRAKES.
This is a VERY clean Impala and it would make some one a really nice cruiser or Hot Rod it is UNMOLESTED!!!!
The car will need to be towed BUT.....I can start the car up for you to prove that it does run, it has the orignal black California plates it is an original california car. The car has been painted once before from the previous owner, ALL of the sheet metal is the ORIGINAL sheet metal the car has NEVER BEEN IN AN ACCIDENT, the bumpers are VERY straight!
Asking $2600 OBO the car is located in Fontana, Ca
Old 11-22-2012, 11:38 AM
Radlark's Avatar
Old 11-22-2012, 11:40 AM
Radlark's Avatar
