Old 11-30-2012, 09:38 AM
gibby gibby is offline
Default Help with 68 camaro
Hey guys just doing some research on the third gen steering upgrade, but I also was having some confusion about the outside steering arms. It seems there are three lengths and I can't seam to decide which is the best to use for a great handling car. Thanks in advance for all your advice
Old 11-30-2012, 01:10 PM
frojoe's Avatar
frojoe frojoe is offline
Presumably you want quick ratio if you're looking at the 3rd gen box, so go for the shortest arms.
Here some good info..
http://www.pozziracing.com/camaro_st...eering_linkage
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
Old 11-30-2012, 10:38 PM
ROBS6T8's Avatar
ROBS6T8 ROBS6T8 is offline
If Pozzi's site isn't enough reading for you, check out this thread on Team Camaro....http://www.camaros.net/forums/showthread.php?t=103139
Might be too much information!
Old 12-03-2012, 05:41 AM
Thanks guys really good info, I can't find te outer arms no one gives the measurements they just say short arms. Any suggestions cpp sells them but they don't give measurements just say they are quick steering outer steering arms.
Thanks for the help
Matt
Old 12-03-2012, 10:17 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
http://www.pozziracing.com/camaro_steering.htm Scroll down about half way and look at "Outer Steering Arms - Three Lengths!" see below
OUTER ARMS
Lengths are from center of spindle between attachment bolt holes, to center of tie rod hole.
Remember, Nova, Ventura, Omega, up through 1974 uses the same subframe as Camaro!
SHORT 5.25" LH-3954875 RH-3954876 Used on power steer, and Z/28 fast ratio manual.
SHORT LH-3902519 RH-3902520 turn stop pad is more pronounced on top, arm appears a bit thinner than later arms. 1968
SHORT LH-3954879 RH-3954880 (listed in parts book as 5.312" long, this may be the actual correct length for all short arms)
SHORT JL8 four wheel disc arms, 1969 Z/28 Heat Treated, Shot Peened, (probably short 5.3") LH 3916237, RH-3916238
MEDIUM ARM 5.5" length RH-3916266 LH -3916265? not sure what ratio. 67 and into 68 manual steer.
MEDIUM ARM 5.5" length RH 3954874 LH3954873 - All except for PS and 302 1969 only.
LONG 6" manual, - LH-3902517 RH-3902518 (67, early long measured at 6") LH-3917193 RH-3917194 slow ratio manual steering.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
