Old 12-02-2012, 08:41 PM
Surfman423 Surfman423 is offline
Default Sway Bar End Links
I can't seem to find any info so I'm hoping you guys will know. I have changed the suspension on my 68 Camaro to 2" lowered Hotchkiss coil springs and 1.5" Hotchkiss Leaf Springs. I am wondering if since I have lowered the front of the car 2", do I need to change the seat bar end links to a shorter set? I can't afford the good Hotchkiss set yet so my stock one will need to remain installed until then.
Old 12-02-2012, 09:42 PM
Track Junky's Avatar
Cut the bolt sleeve down and get to a shorter bolt if needed. Try and set sway bar up so that it is parallel to the ground at ride height.
Gaetano Cosentino
