Old 12-18-2012, 03:57 PM
rocketrod rocketrod is offline
Default 1st Gen with Ridetech Airbar: Get Link Bars with Poly or Heim joints?
For those that have installed this setup would you recommend getting poly or heim joints for the links bars? The car will be mostly street driven, but I would eventually like to autocross it some. I have heard the heim joints can be noisy and only necessary for a car that will be autocrossed a lot.
Rod
1969 Camaro - LS2/4L70E
Old 12-19-2012, 02:44 PM
With all the Ridetech installs around here I figured someone would chime in.
Rod
Old 12-19-2012, 07:13 PM
GeoffP GeoffP is offline
I was hoping someone would chime in too...curiosity mainly since I've already order my 4 link with Heim joints.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 12-19-2012, 07:23 PM
bret's Avatar
bret bret is offline
Supporting Vendor
In reality you can use either. If you're really going to chase the autocross and road course thing, use the heim ends. They eliminate the last little bit of flex and allow that last little bit of articulation. Our heim ends are Kevlar lined and stay tight and rattle free.
If you're doing a few events per year, just stick with the poly ends. They do eliminate just a little nvh over the heim ends, but it's pretty minimal.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 12-20-2012, 06:21 PM
Bryce Bryce is offline
Bret,
Whose heims do you use?
Old 12-21-2012, 07:41 AM
bret's Avatar
Supporting Vendor
QA1 and FK
Bret Voelkel
President
RideTech
