Old 12-23-2012, 02:08 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Default RapidAir - Maxline?
I'm having a new home shop/garage built and I will be finishing the inside out - ie: wiring, plumbing air lines, insulating etc..
I've been looking at various air line options. I like what I see with regard to the RapidAir Maxline. Does anyone have any experience with it?
I'm open to other suggestions as well. I'm still debating whether I will run the air lines inside the wall or external. I'm leaning toward running them external (wall mounted).
Thanks for any input.
Here are a couple of links.
http://www.rapidairproducts.com/maxline.asp
http://rapidairproducts.com/pdfs/Maxline-Brochure.pdf
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-23-2012, 02:30 PM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
Brandon, we used the 3/4'' maxline kits throughout our shop when we were getting things up and running. Also used it to run air supply to our Garmat booth. Stuff worked out great and people at Rapid Air products are helpful and nice too. We ran line on outside of walls. Any question's give me or Paul a shout. Joe
Joe VanNus
Old 12-23-2012, 02:54 PM
wiedemab's Avatar
Thanks Joe!
I won't be doing paint work or anything at my house shop, but I will be using air tools etc.. I was thinking of going with the 3/4" setup and making a complete loop around the shop.
Once I get to the point of installing air lines, I may give you guys a shout.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-23-2012, 04:46 PM
Fluid Power's Avatar
We sell the Parker Transair stuff. Very nice for sure. The pipe is not very expensive but the fitting prices will amaze you!
Darren
Old 12-23-2012, 08:07 PM
IMPALA MAN IMPALA MAN is offline
I have it in my home shop and it works great. Easy to install and works. Just my 2 cents
