Old 01-01-2013, 01:06 PM
HEEP's Avatar
HEEP HEEP is offline
Default Chevelle Frame Rail Narrowing
Ok, I have searched and read every thread on this subject. However, I could not see where anyone stated just how much was gained. What I am looking for is just how much you can gain from reducing the width of the frame rail itself. This is not narrowing the rails to create a four link drag race type setup. I am looking to add a larger tire in the rear. I'm set on a minimum of a 19" wheel, and my understanding is that I can get a 10" width under the well without any modification.
I have even thought of going full force and ordering these and grafting them in.
http://autoweldchassis.com/spec.ivnu
these are 3" tube that are supposed to fit under a stock body according to the company.
I am at the place where i need to make this decision so I can either move to the next step or stat cutting the frame.
Thanks in advance,
HEEP
Old 01-01-2013, 01:31 PM
Che70velle's Avatar
Check out Scott Mocks 66 Chevelle build thread on here. Go to page 13, post 125. He narrowed his stock rear frame, and looks to have 315's back there. Actually he's got those tires on all 4 corners!
How wide do you want to go? I'm running 10" wheels out back, and I'm sure I could do an 11" with cut or rolled fenders, and the perfect back spacing.
Thanks Dad!!
Old 01-01-2013, 02:27 PM
67goatman455 67goatman455 is offline
You have a 68-72 car right? On my 67 i gained an inch and a half by reducing the width, but the earlier models frame is slightly different.
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 01-01-2013, 03:20 PM
Vince@Meanstreets's Avatar
Thanks in advance,
HEEP
Due to the shape of the frame you will run into issues near the front.
this is a better solution.
http://abcperformance.net/mini%20tub%20kit.html
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-01-2013, 06:03 PM
HEEP's Avatar
Vince, I've looked into his kit. He is just now finalizing his build on the 70 models. He has the 66-67 taken care of. I just sent another email to him to see where he stands.
Might have to buy myself a late Christmas present.
I checked out Mr. Mocks Chevelle. That is the ABC kit installed. I'm ready to start cutting , I guess after I brace everything first.
HEEP
Old 01-01-2013, 06:04 PM
Thats why i was asking. I found out this kit was available 2 weeks after i just cut it up myself.
1967 GTO, LS2 T56
Old 01-01-2013, 06:51 PM
Me too, I ended up going the opposite way with it.
Dealer for
NEVER FORGET -11
Old 01-02-2013, 05:03 PM
Pictures???
1967 GTO, LS2 T56
Old 01-02-2013, 06:50 PM
HEEP's Avatar
X2
Old 01-02-2013, 11:53 PM
I had a few floating around here....well the mock up picture was taken 5 years ago and it sucks. I'll have to make a project thread since we have started working on it again. Just got it back from the media blasters and should have the sheet metal back on it in April. Stretched 1 1/2" using new quarters fitting 315's on 11" wide rims and a 5 1/2" back space.
I figured I would see if it would work since I have to put new quarters on it anyways. Plus narrowing the frame and mini tubs is very time consuming job. Body sits on 1/2" spacers and the front is "Z"ed 1 1/2" up.
Dealer for
NEVER FORGET -11
