Go Back   Lateral-g Forums > Technical Discussions > Safety Equipment
Old 01-05-2013, 11:24 AM
Track Junky's Avatar
Default Fuel Cell Cage
I have an ATL Fuel Cell on the way and was researching fuel cell cages. I attached this link for anyone else that might be interested. Once I get started I will add how we decided to mount it on my build thread.
http://www.circletrack.com/safety/ct.../photo_01.html
Gaetano Cosentino
Old 01-05-2013, 03:31 PM
Vince@Meanstreets's Avatar
low and forward.....does this mean you get to hack up your trunk floor?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-05-2013, 05:02 PM
Actually this means you will be hacking up my trunk floor.
Gaetano Cosentino
Old 01-05-2013, 05:07 PM
Sieg's Avatar
Sieg Sieg is offline
Yes you do and that will be the easy part.
Old 01-05-2013, 05:20 PM
Flash68's Avatar
Flash68 Flash68 is offline
Right there with you G. Which particular cell did you get? There are so dang many options.
I already had the hole in mine with the plastic tank and I found the used Fuel Safe tank with about the identical dimensions so we'll drop it in.
Good link - thanks!
I thought I'd seen that article or one similar. Here is a link I had saved on my endless spreadsheet:
http://www.circletrack.com/safety/ct...e_in_the_city/
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-05-2013, 05:34 PM
I got lucky and found a brand new SP108 that is FIA aprroved and FT3 rated for $389 shipped. He had bought it for his race car but ended up not using it. Saved me close to $250. I wanted to go with the Fuel Safe because of the shallower depth dimension in the 8 gallon but they only have one pick up. The ATL's have dual duck foot pick ups.
Gaetano Cosentino
Old 01-05-2013, 07:38 PM
FETorino's Avatar
FETorino FETorino is offline
Nice score
Rob in SoCal
Old 01-05-2013, 10:04 PM
Thanks Rob. I thought for sure I'd be picking it up from Pitstopusa after talking to you. Gave ebay a go the next day and there it was. Good thing there aren't a whole lot of racers interested in 8 gallon cells. I was the only bidder.
Gaetano Cosentino
