Old 03-29-2006, 02:37 PM
fjb2069's Avatar
fjb2069 fjb2069 is offline
Default clutch actuator fitting
I am trying to find the part number or part (if someone has one) for the hydraulic line and fitting the comes off of the clutch actuator and plugs into the line of the clutch master cylinder for a 2000 firebird.
THe clutch actuator is part # 12565145 and the master assembly is 12570277, just need part in the middle!
Old 03-30-2006, 06:34 AM
Payton King's Avatar
Default line
not sure that you can get that seperate. I have one from a wrecked car but I may be using it...I will keep you posted.
Mcleod now makes just the line kit without the restrictor that most drill. Go to www.thunderracing.com and look it up. I believe that it is around $150.
