Old 01-09-2013, 09:39 AM
Gandalf Gandalf is offline
Default Moser 9" housing & 31 spline axles
Moser 9" housing narrowed & built for 1st Gen w/DSE mini-tubs. Has big Ford Torino ends and has been powdercoated (has marks from mounting etc).
Total overall width is 55.5". Comes with pre-welded mounts for GBar (RideTech v1 4-link). The mounts/tabs either need to be moved or you can use in a custom setup or cut them off and use something different. This setup probably has 500 miles on it before I removed.
Moser 31spline axles for the above setup. Has the Wilwood access holes and 1/2" x 2" studs. Had to replace because my new housing center-offset was not the same as the first so needed new axles. Bearings still pressed on and ready to run.
No other parts included. Selling housing and axles only.
Both Housing and Axles boxed up in their respective Moser boxes. Prefer local deal but will ship at buyers expense. If near the west coast - I'm sure we can work something out. If you are in SoCal - I'm happy to meet. Location is San Diego.
G.
Old 01-09-2013, 01:23 PM
cencalc6 cencalc6 is offline
Great Deal!
Old 01-09-2013, 06:06 PM
p51mus p51mus is offline
Default housing
PM sent.
gb69z
Old 01-10-2013, 05:46 AM
130fe 130fe is offline
Thumbs up
PM sent.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-12-2013, 05:03 PM
The T-man The T-man is offline
Old 02-25-2013, 11:57 AM
Sold.
