Old 01-10-2013, 12:34 PM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Default 1967 Corvette at Roadster Shop
With all the latest RS updates it only makes sense to start a new thread on this '67 which arrived a few months ago and has seen some pretty major reconstruction. It can sometimes be easy to forget just how much work can go into a fiberglass car to either modify or bring it back to life with correct gaps, bodylines etc. (You can't hammer and dolly a fiberglass fender or run pieces through a shrinker/stretcher!)
Plans for the car are a fairly mild, factory appearing exterior, enlarged rally style rims and traditional color palette. It will be receiving a FAST TRACK C2 Corvette IRS Chassis, and plans for an LS7 drivetrain.
The car as arrived:
Teardown:
Chassis construction:
The chassis is now one of our production FAST TRACK chassis, details of which you can check out here! : http://www.roadstershop.com/products...rvette-chassis
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 01-10-2013, 12:40 PM
Gorgeous as always!
Old 01-10-2013, 12:47 PM
RS-Chris's Avatar
Supporting Vendor
A few color options and an idea of how the wheels will look:
With the chassis done, work commences on the body. Peeling back the outer layers, reveals quite a bit of prior body damage, cracks, cavities etc.
Fab on the rearward floor and trans tunnel. (NB: we dont normally do the mini-trucker grinder treatment on our sheetmetal: in this case, it's to give the sheetmetal 'tooth' and help the bonding of the new glass!)
No chopper guns here!
Old 01-10-2013, 12:52 PM
RS-Chris's Avatar
Supporting Vendor
Underside and rearward floor:
Smoothing the firewall and removing factory apertures.
Old 01-10-2013, 01:12 PM
strtcar strtcar is offline
Nice build, I like that yellow color in the drawings.
Old 01-10-2013, 01:15 PM
RS-Chris's Avatar
Supporting Vendor
Old glass front and the new replacement behind:
Quarter panel repair. (The full gallery on our site shows more of the many repairs were needed to the body - http://www.roadstershop.com/current-.../1966-corvette)
And beginning to resemble a Corvette once more:
Old 01-10-2013, 02:23 PM
KPC67's Avatar
KPC67 KPC67 is offline
anything and everything your guys touch turns into gold!
Kevin Carter
Old 01-10-2013, 05:42 PM
coolwelder62's Avatar
Just another Amazing Build. The fiberglass floor work is really cool.
Old 01-10-2013, 05:51 PM
Rick D's Avatar
Rick D Rick D is offline
Wow that floor looks sooooo factory!
Rick
Old 01-10-2013, 06:28 PM
Red is always a great Corvette color....
But then again -- my first one was Silver....
But then again -- an Ermine white coupe looks clean....
Steve Frisbee painted this in lacquer in a two car garage 30 years ago... It still only has 34K original miles
But I've had Blue that I liked too....
The only yellow on a Corvette has to be factory Sunfire Yellow... black stinger...
