Old 01-10-2013, 11:08 PM
black67malibu black67malibu is offline
Default LS2 clutch questions.... HELP!!
Hello, I just purchased a LS2 out of a 2006 GTO and am putting it into a 67 chevelle. Ive searched and cant seem to find any info on whats necessary to get the clutch to work in my car. With the Motor and trans I also got the stock pedel assembly, slave, reservoir and all the clutch lines. Do I try and put this pedel assembly into the car or do I have to buy an aftermarket setup? also looking for info on what clutch to run. I've serched and it seems the SPEC, monster, and competition clutch seem to be the favorite. Any info would be greatly appreciated..
Old 01-12-2013, 03:47 PM
Any info? What pedals, slave ect...
Old 02-04-2013, 06:09 PM
Vince@Meanstreets's Avatar
did you ever get the info you were after?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-05-2013, 10:09 AM
I think so...
I ended up buying the ATS master bracket and stock chevelle pedals. One question I still have is if I can use the stock GTO master or if I should buy the camaro master. I ended up getting the Monster stage3 clutch kit with the optional braided line.
