Old 01-18-2013, 08:51 AM
redfire69's Avatar
redfire69 redfire69 is offline
Question new Silverado ticking on cold start
I've got a new 2012 Silverado HD2500 with a 6.0L gas engine. It ticks for a few seconds on cold startup. The colder the worse. Does anyone know if this is normal? Hard to believe out of a new vehicle.
Ron
69 Camaro Redfire
Old 01-18-2013, 10:04 AM
Vince@Meanstreets's Avatar
no, i'd bring it into the dealership. how many miles? does it sound like internal engine or could it be a belt noise?
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-18-2013, 10:08 AM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
Take video or audio of it and post up. Mileage on truck also please. Could be a bad lifter or afm lifter if u have dod. I can check for tsbs when I get back to work after lunch.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 01-18-2013, 11:09 AM
redfire69's Avatar
Sounds like an internal lifter noise. Truck has 500 miles on it.
Ron
69 Camaro Redfire
Old 01-18-2013, 11:41 AM
ccracin's Avatar
ccracin ccracin is offline
Check the oil level. Sounds simple, but!!!!!! My Dad's 07 has done this since new. When he first heard it he checked the oil and it was off the stick. In the end it used more than 3 quarts of oil in 3500 miles. He had an ongoing battle with GM about it. They kept trying to fix it kept burning oil. Here is a short list, new valve covers, new oil baffles, new breather parts, new valve guides and seals, and finally all new pistons and rings. Before he got to the pistons and rings he contacted a lemon law lawyer and got a settlement. He did not get a new truck because he did not report the issue soon enough. My advise is get it to the garage and get on record asap. They did the pistons and rings while his case was in progress. This seems to have mostly solved the issue. I can not tell how much of a pain it was to deal with. His truck is an 07 and he just got finished with the issue last summer. 4 Years! Good Luck!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 01-18-2013, 12:20 PM
Roscoe03 Roscoe03 is offline
AFM lifter would be my guess too. I've read numerous issues of people on the chevy/gm fourms, of people having lifter issues because of the dod. Many people choose to get a custom tune to delete the dod and it solving the issue.
Old 01-18-2013, 12:29 PM
redfire69's Avatar
Oil level is good. edit: how can I tell if my truck has fuel management. It's a 2500HD, I didn't think they had this feature.
Ron
69 Camaro Redfire
Old 01-18-2013, 03:27 PM
Window sticker?
Put up the last 8 of your vin. Some of the dealer guys here may tell you.
Dealer for
NEVER FORGET -11
Old 01-18-2013, 03:32 PM
2012's came with it. GM calls it Variable valve timing.
http://www.chevrolet.com/2012-silver...owertrain.html
Also if you have a DIC, you can switch it unitl it displays the V8/V4 mode and it will tell you as you're driving which mode you're in.
Old 01-18-2013, 05:53 PM
Bring it in to the dealer. Have em look at it. I have had a few bad lifters in new trucks. LY6 engine does not have afm. If is a 2500hd most likely LY6. Could also be bad oil pump or incorrectly installed oring. I am a heavy line tech for gm dealer and seen all these problems. Also u mentioned ur truck is a '12 model. Being we are now on the '13 there is a possibility ur truck has been sittin on the lot for a while. A simple oil change may solve the problem.
1969 Chevy Nova
2007 Chevy TBSS
