Old 01-18-2013, 11:26 AM
AmKenpo1's Avatar
AmKenpo1 AmKenpo1 is offline
Default Floater Axle Splines
Can I ask those of you currently using floater assemblies what spline axles you have? What spline would you like to see in a floater kit?
Thanks in advance for your feedback.
Wil.
Strange Engineering
Old 01-18-2013, 12:18 PM
dontlifttoshift's Avatar
35 spline
Donny
Old 01-30-2013, 04:03 AM
Kawaden Kawaden is offline
I'll be needing 35/24 spline. Wavetrac center with Baer floater.
Old 01-30-2013, 01:26 PM
Flash68's Avatar
Flash68 Flash68 is offline
Wouldn't 31 suffice for most people?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-30-2013, 03:20 PM
31 would cover most people but 35 covers 99%.
The roadster is 31 interior and 35 exterior, honestly in that (roadster) application 31spline is overkill........I like overkill.......
Donny
Old 01-30-2013, 03:35 PM
AmKenpo1's Avatar
Thanks for the response guys. We had originally thought of going with the NASCAR standby 24 spline, which if you didn't know actually is 1-1/2" in diameter like the 35 spline, but we have decided to make the change to 35 spline.
I will post more information as it becomes available.
Wil.
Strange Engineering
Old 01-30-2013, 11:32 PM
FETorino's Avatar
FETorino FETorino is offline
31 spline for me. Those wimpy 200tw tires should surrender first.
Rob in SoCal
Old 01-31-2013, 12:59 AM
intocarss's Avatar
From Moser
"To achieve maximum performance you should use the smallest axle that will safely handle the torque your car produces
Each axle should be able to handle all of the maximum torque your car can produce. That way it is practically impossible to break an axle because you have at least 200% saftey factor
30 Splin- 6,200 ft.lbs. (per axle)
31 Splin- 7,000 ft.lbs. (per axle)
33 Splin- 8,200 ft.lbs. (per axle)
35 Splin- 9,600 ft.lbs. (per axle)
40 Splin- 12,000 ft.lbs. (per axle)
Old 01-31-2013, 06:54 AM
That's a good, general chart. 500lb ft x 2.97 x 3.89 = 5,776. So in theory 30 spline is enough to hold most cars.
Even Mayehm, with the way it is geared, is below the requirements for 35 spline.
Donny
Old 01-31-2013, 10:49 AM
AmKenpo1's Avatar
Thanks for the information.
Wil.
From Moser
Strange Engineering
