Old 01-27-2013, 11:07 AM
IMPALA MAN IMPALA MAN is offline
Default Ricks's Tank for 66-67 Chevelle
A local welding shop took in this tank to repair. The straps holding it in the car came loose and the tank fell. The shop repaired the area, pressure tested it and by then, the owner went a different route. The tank is a fuel injected version, and the in tank pump is included, as seen in the photo. The straps (that failed) DO NOT come with the tank, they are being disposed of. what you see is what you get. AS IS. It is gaurnteed not to leak, however once you install it, it's yours. This tank sells for about $1,100.00 new. This one is up for $500.00. PM with questions.
Old 01-27-2013, 02:21 PM
Mt69z28's Avatar
Mt69z28 Mt69z28 is offline
Default gas tank
hi there, wonder if this would work in a 65 chevelle ? Thanks, Mike
Old 01-27-2013, 04:31 PM
Sold!
