Old 01-30-2013, 10:50 AM
fireboy68 fireboy68 is offline
Default Art Morrison Crossmember & Tranny Mount?
I am building a 68 camaro with an Art Morrison front subframe. I have an LS3 with a Tremec T-56 tranmission in the car. Is there a special transmission mount for the T56? The stock chevy mount is too short, the holes wont line up to the transmission, and when i set it all in the car the transmission mount's holes dont line up with the crossmember. Make sense? Anyone have this problem?
Thanks for any input!
Jeremy
Old 01-30-2013, 11:03 AM
ccracin's Avatar
ccracin ccracin is offline
Give Morrison a call. They are great to work with.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 01-30-2013, 02:46 PM
Ron in SoCal's Avatar
Yeah, something doesn't sound right. The mount is made to move forward and back as needed. What bell housing are you using?
Edit: are you referring to the tranny mount between the trans and cross member? I used an energy suspension mount and everything lined up, more or less.
Ron in SoCal
69 Camaro in progress
Old 01-30-2013, 09:09 PM
Default Trans mount
Yes the trans mount and the cross member. It seems like the bracket thats welded to the crossmember isnt deep enough for me to bolt the energy suspention bushing (or mount) to the crossmember. I cant flip the crossmember because it is too high and my pinion angle will be way off if i did.
Also the holes is that trans mount dont match the holes on the transmission. Maybe i will have to post a pic. I feel like a nuckel head trying to explain this
Old 01-30-2013, 09:28 PM
Default Just my luck!
Ok so i went to the Art Morrison website and looks at some pics of another camaro. Turns out the tab on my crossmember appears to be welded on upside down according to the pics from their website. I thought i was going crazy for a minute. Good thing i have the technology to fix it myself
Sorry for the silly question, thanks for the help guys!
Jeremy
Old 09-19-2013, 01:33 PM
RocketsGarage's Avatar
RocketsGarage RocketsGarage is offline
Do you still own this car?
