Old 02-02-2013, 09:28 AM
Default About Door Bars.
Anyone have any opinions about Door Bars? I am having a cage built and I wanted to look for advice. I dont want the 45% divide coning down.. its too much of a cage for a street car.. but if I have them I want them to server the purpose they were intended to do...... I like the style used on the Tiger cage but wasn't sure if they actually provided protection of it they sere just for looks.
Old 02-02-2013, 10:12 AM
Vortech404 Vortech404 is offline
TigerCage is NOT currently certified for racing in NHRA or SCCA sanctioning bodie just so you know.
I suggest you take a look at the cage rules at www.nhra.com for some info on cages, driveshaft loops etc...
later
John
Old 02-02-2013, 10:38 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Are you drag racing the car?
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 02-02-2013, 01:44 PM
i would like to comply with SCCA and for NHRA i expect to be above 10 seconds were it starts to get strict... last i remember for 10.90 you only needed a DS loop, secured axles and a simple 4 point rollbar
Old 02-02-2013, 06:02 PM
WILWAXU WILWAXU is offline
I had a removable door bar in my 2001 Formula. It met all the safety requirements and when removed didn't get in the way.
Careful though.. meeting NHRA requirements is a slippery slope. Once you have a roll bar.. you then need 4 point harnesses.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 02-02-2013, 06:42 PM
Shmoov69's Avatar
Shmoov69 Shmoov69 is offline
I got removable door and "back" bars in my Camaro. I got the bolt in style that takes two countersunk Allen bolts on each joint. It is awesome and stiffened it up A TON!! After seeing Tim's nova pop the quarter panel when his pin style came loose at the MMCC a few years ago, I decided to go with a more rigid style.
https://www.ballisticfabrication.com...sp?itemid=1467
Jimmy
69 Camaro - Twin Turbo'd
58 Nomad -348 Baby Rat
www.fquick.com/shmoov69
Old 02-03-2013, 08:23 AM
Steve Chryssos's Avatar
Unless you're building a 10.90 car -- which is doubtful -- run a four point bar. If you want more protection, add a halo and a-pillar bars through the top of the dash, then connect them with a sill bar 1" above the door sill. Unless you can bring the power AND the traction, forget the NHRA guide.
________________
Steve Chryssos
Ridetech.com
Old 02-03-2013, 08:31 AM
Blake Foster's Avatar
with out the side bar crossing between your shoulder and elbow it will NOT be NHRA legal.
and SCCA is totally different. you need to check the class rules. but either way it will be a PAIN for street driving.
i have my door bars down low same height as the seat pad. so not legal for any class but i figured with the full cage it may help some what in a frontal or side impact. it is still a PITA to get in and out.
Blake Foster
www.speedtechperformance.com
Old 02-03-2013, 09:00 AM
Bryce Bryce is offline
It is hard to build a cage with door bars that meet all of the regulations of every sanctioning body. Pick the one you will race the most and build it per those rules.
Old 02-03-2013, 12:13 PM
Vince@Meanstreets's Avatar
I had a spring loaded swing out bar on my Sportsman car. The lock was made by Alstons and was legal to 8.50. Works better than a pin.
http://www.alstonracing.com/Catalog/...13%2011-9a.pdf
top of page 7.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
