Go Back   Lateral-g Forums > Help, Feedback and Testing > Vendor/Member Feedback
Old 02-06-2013, 08:18 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Thumbs up D&D Performance
Thanks to D&D Performance for their technical assistance and quick turnaround on a parts order. last week I ordered a special custom made aluminum spacer to mount a T56 Magnum transmission to a QT bell on an LS engine using a ZR-1 twin disc clutch. They knew exactly what I needed to make the combo work.
I placed the order for the custom spacer on a Monday and received the part on Friday the same week. The part quality was great, and everything fit together with no mods required. Good guys there at D&D.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
