Old 04-01-2006, 08:08 AM
corys69ss corys69ss is offline
Default 275-35-18 Toyo's up front
Is it possible to fit 275-35-18 up front on a 8.5" 69 Camaro with a stock sub frame. I will be running 335-30-18 RA-1's in the rear. I do not mind some rubbing. Also, what bs would help squeezing the monsters under the fender. I am in the middle of ordering HRE 840 R's, so it is crucial I get it right. Thanks Cory
Old 04-01-2006, 10:02 AM
I just spoke to my HRE wheel guy, and he said a 18x9 would fit my car. Anyone know this to be true?? By the way I am running Speed Tech upper and lowers with QA1 12 ways. Rear is mini-tubbed with 3" DSE springs. I am looking for a stance like SW's black 69.
Old 04-01-2006, 10:11 AM
68protouring454's Avatar
Default yes
you need at least a 9 to run most 275/35/18, i am going to run a 9.5 up front, however this size will not work on most set-ups and very few run this sizze on a stock sub, what are you using for control arms etc?? look up carlc he will help you.
jake
Old 04-01-2006, 11:15 AM
Jake, I am running Speed Tech upper and lowers with QA1 12 ways, and DSE steering box. What bs for a 18x9?? I will try to contact carlc. Thanks for the info. Cory
Old 04-01-2006, 11:55 AM
probaly 5.25 bs, but i am not going to be the one to verify that, i am 95% sure carlc is running 17x9.5 with 5.5 on all 4 corners of his 68 camaro,
jake
Old 04-01-2006, 01:11 PM
MadMax MadMax is offline
I thought that the 67-68 fenders had a little more room in them because they were "boxier" or something. I'd def. talk to carlc.
Old 04-02-2006, 07:19 PM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
before you ever purchase wheels you should make a small investment in a device that will verify your bigest wheel size
here is the link for company that sell just what you need
http://www.percyshp.com/producthomewheelrite.html
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
