Old 02-09-2013, 07:12 PM
andrelossem andrelossem is offline
Default Pro touring fox body
I would like to Know how hard it's going to be to get 285/35/18fr. and 315/35/18 rear tires on my 90 LX fox body.I have the MM k-member and rev.. set a-arms. For the rear I'm going with Cortex watts link and torque arm. What rim size in width and help with off set. Thanks !!!!!!!!!
408 LQ9 L92 heads
4l80 trans.
8.8 rear stock gears.
Old 02-10-2013, 01:56 PM
pahela2 pahela2 is offline
Default Reply
Without mini- tubbing the car it will be tight. You will need to roll the outer fender lips . Also get yourself a 3 lb and 4 lb hammers and go to work on the lower half of the inner fender wells. 5.0 magazine did a article on fitting 315's on a fox body. 10.5 or 11 inch rims will need a 6.5 bs at minimum .
Link to 5.0 article
http://www.mustang50magazine.com/tec...s/viewall.html
