Old 04-01-2006, 02:56 PM
DAWG's Avatar
DAWG DAWG is offline
Default 69 camaro rear door panel install problem
got a set of pre assembled door panels (PUI interiors)
the rear panels are pissin me off to no end.
i got the passenger side in after much swearing etc.
the drivers side is high at the door edge side but the panel lines up with the door?
the metal insert didnt seem to match the originals and got it to fit somewhat better after tweaking the metal insert.
but the window knob hole is slightly off and the knob hits the mylar trim piece.
this is on a 69 camaro std interior
SIT DOWN _SHUT UP_HANG ON
Old 04-04-2006, 09:58 AM
DAWG's Avatar
yeah thks for the quik replies guys!
Old 04-04-2006, 10:27 AM
Payton King's Avatar
Default no answer
Can't reply when I don't have an answer. I really think you answered your own question in that the pre-assembled panels do not fit as good as the originals due to the upper portion where the metal is located....it sounds to me that they were a bad batch and need to be sent back. If you have your originals I would get the ones that are not pre-assembled and remove the metal upper portion and go that route.
On a related note...do you have those subs installed under the seat yet?
Old 04-04-2006, 03:54 PM
DAWG's Avatar
yes I do but took em back out to do the carpet install and door panels.
ill post a pic when done
Old 04-06-2006, 07:44 AM
Default panels
Did you get the rears to fit?
Old 04-06-2006, 11:17 AM
DAWG's Avatar
here is the pics after wrestling them for best fit:
notice the holes in window reg are off.
and drivers side still too low in back ( but have 1 " gap at rear window trim.
drivers side has new panels installed.
passenger side only rear panel installed.
Old 04-06-2006, 12:32 PM
Default well
good thing is the crank will cover the offset hole and nobody will notice since it is in the back...except you. The real stuff does not fit that great either if that is any consulation.
Old 04-07-2006, 08:12 AM
DAWG's Avatar
originals dropped right in and fit really good actually.
they were just worn out a bit.
anyhow Classic wants em back.
btw wife doing my seats in black leather but wont do the panels lol.
Old 04-18-2006, 07:21 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Remember to put the cups and springs back in between the handle and the panel.
Jim
Old 04-18-2006, 10:29 PM
69onmymind 69onmymind is offline
Default Rear Panels/Interior
Dawg,
Did you lay down Dynamat (sound deadener) before you laid the carpet and panels? If so, how was it? I'm at this stage now with my 69.
Joe
