Old 02-13-2013, 08:27 PM
1Bad68Cat 1Bad68Cat is offline
Default Rick's Tank with Vapoworx
Hello everyone,
Just wanted to get some suggestions as to what to look for. I purchased the aforementioned tank fro my 66 c10 and ran into a small problem (hopefully). I have not dropped the tank yet to see what is wrong, but plan to this weekend. Just to give you an idea of the problem, the truck acted like it ran out of gas even though it is half full. After I got it towed home, I was able to start it again, but it did not run right. I backed it into the driveway and it began to run normal. I was afraid if I took it out for a spin, it would have quit working again. I checked the easy stuff, fuse, relay, wiring etc. but did not find anything unusual. I had driven the truck with the new fuel system for a couple of months and even towed a car home with it. When I drop the tank, what should I look for that may not be obvious.
Thanks in advance,
Robert
