Old 02-18-2013, 03:36 PM
70chevellemalibu 70chevellemalibu is offline
Default 70 chevelle wheel combo...thoughts
Hey all,
I found a set of Ronal LZ 20x10 and 19x10s 2 (piece rims) locally brand new in box for a C5. The owner has stated that the backspacing is 7.25" he is selling them for $600.00. I am thinking of having the offset changed to a "Chevelle offset"/backspacing which can be done locally for $75.00 each.
So in the rear i know the 20x10s ill need a 5.5" backspacing and the fronts i am assuming 5.5-6.5" of backspacing BUT will i have problems with a 10" wide wheel upfront?
Should i look into cutting the wheel down to 8" wide while doing the offset change?
Then powdercoat and refinish the wheel for about $500.
This may seem like a weird way about going to custom wheels but going with Rushmorth or something similar is just way out of budget.
The car wont be needed wheels till fall so should i wait it out and find another wheel that will work used or something else?
My plans for the car will be QA1's coilovers all around and C6 or CTS V brakes all around.
any input is appreciated.
Old 02-18-2013, 05:19 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I think you will be cool with a 19x10 up front as long as you don't plan on lowering the car too much. Also, depends on the size tire you run as well.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
