Old 02-23-2013, 08:41 PM
69CamaroPT 69CamaroPT is offline
Default DSE PS Hoses
Has anybody had issues with blowing DSE's PS hoses? I blew another today about 4500 miles on car after the first one blew. Running DSE PS pump and 12.1 box. Line is popping through in the line not at fittings. Thoughts/ suggestions
69 Camaro
67 GTO vert
Old 02-25-2013, 07:13 AM
67XR7's Avatar
67XR7 67XR7 is offline
What pump are you using? Did it pop in the same exact spot(sharp edge etc.making contact with the hose)
1965 Chevelle, Pm me if interested in wheel tool rental
Old 02-27-2013, 07:14 AM
I am using DSE's ps pump with integral reservoir. No the hoses are under motor mount on subframe. They are not near any moving parts that could cause rubbing. It did pop near the subframe as the line curves up to pump. No kinks in line either.
69 Camaro
67 GTO vert
Old 02-27-2013, 09:02 AM
dontlifttoshift's Avatar
So the hose ruptures in the middle, not at the fitting connection?
Is it teflon hose? If you are using rubber hose with a stainless overbraid on the pressure side there is your problem. The rubber based braided hose is only rated for 350 psi.
Donny
Old 02-27-2013, 04:41 PM
Ns RS's Avatar
Ns RS Ns RS is offline
I had the same problem with DSE hoses -purchased Feb 2012. got a RMA/RGA# (return merch #) and exchanged it with without a hassle, the 2nd set has held up so far.
The leak started below the fitting and dripped onto the sub (left side on the pic) - had the plastic bag in place to try to zero in on location. Sorry for the poor cell pic.
Old 03-01-2013, 06:01 AM
Jay Hilliard's Avatar
I have the same issue leaking on return hose. I will make a call today.
Jay
Old 03-01-2013, 12:26 PM
71RS/SS396's Avatar
Jay, did you use a piece of heat shrink on the plastic nipple on the reservoir? If not that's likely why it's leaking, the teflon lining on the hose won't seal on the plastic nipple without the heat shrink.
Old 03-03-2013, 07:55 PM
I did not put the heat shrink on. I will do that and hopefully that will fix it
Thanks Tim. Hope you are doing well.
Jay
