Old 02-26-2013, 04:39 PM
Bad Bowtie Bad Bowtie is offline
Default Ring gear ?
Ok guys here's one for you differential gurus. Hopefully this isn't a stupid question but I am wondering if there are any benefits to using studs in the ring gear vs using bolts ? I'm inquiring on this because i've never heard of it being used (and there could be a good reason not to). I'm not even sure if such a stud is manufactured or on the market. I know alot of engine builder use cylinder head studs instead of bolts for better clamping force and help saving the block threads. Just checking with some of you guys to see if you have ever seen or heard of this practice. Looking forward to your replys
BB
Old 02-28-2013, 09:14 AM
Wow no one has any experience with something like this , interesting !
Old 02-28-2013, 12:53 PM
67ragtp 67ragtp is offline
BB,
I recently did a gear swap on my rear and used ARP fasteners, when I spoke with the techs at ARP I asked them this same question, they said in most applications its a clearance issue. Many ring gear bolts use a low head, dont want studs sticking out to high.
Rich
Old 02-28-2013, 03:48 PM
Todd in vancouver's Avatar
Todd in vancouver Todd in vancouver is offline
agree with above. any gear changes that I've personally done are tight for room inside the diff and I don't recall there being any extra space for a stud to hang out
Todd in Vancouver, Canada
'67 Camaro SS
How hard can it be?
Project Obsession
https://lateral-g.net/forums/showthread.php4?t=40384
Old 02-28-2013, 04:39 PM
intocarss's Avatar
As stated above, It's a clearance thing
Old 03-01-2013, 05:03 AM
You guys are awesome, for the world of me i dont know why i didn't think about that. I'm getting ready to assembly a 12 bolt and was just curious about the use of studs vs bolts. Things are very tight in there for sure.
Thanks for the responses guys
BB
Old 03-13-2013, 08:43 AM
468Camaro's Avatar
468Camaro 468Camaro is offline
Studs on the caps is good, also they have those girdles to stabilize the caps..do it :p
Bowtie Nutt 68 Camaro Pro-Street 2x3 Ladder bar -backhalf 32x14 Dana 60 5.38, 406" 12-1. .Chet Herbert Billet Roller .645" 106' .Brodix Trk1, 830" Annular,Victor.glide-brake.. Needs Real windows.. 1989 Vette Z-51 357" 4bolt Forged, Dart IIS,Comp cam..Billet Specialties, 86" Iroc-z 468-400 ,2003 Roadstar 102" ..
