Old 03-02-2013, 04:20 PM
Mr Furley Mr Furley is offline
Default Green Manilishi 1972 Cutlass S
Technically the car is black at the moment but the plan is to return to the original green hue or something close to it. I'll call it "Joe" Touring or a Pro Touring car for the average Joe, if there is such a thing. Really this is all a clever way of saying I am cheap/cannot afford a full boat build so I'm hitting the important points.
Engine: LS1 out of a 2000 Firebird. Plan is to clean it up, LS6 intake it, cam it and enjoy it for a bit
Trans: T56 out of the same Firebird
Suspension: Ridetech Stage 2 Coilover kit
Other: Clean the car up and drive it!
Started today by pulling the front clip off
Looks like I'll need to replace a fender, lucky the rest of the rocker was rust free under the trim!
Tomorrow I plan to pull the motor and trans out and prep and paint the frame, my LS1 arrives Tuesday!
Old 03-02-2013, 04:39 PM
coolwelder62's Avatar
Nice build.These car's don't seem to get enough Love.Look @ the ridetech shock's when are pricing the suspension componet's.They really work great.
Old 03-02-2013, 06:42 PM
I think the factory green that Olds put on say a 70 Cutlass is gorgeous. I like that plan you've got going. Good luck.
Old 03-06-2013, 09:04 AM
Updates(which are near worthless without pics):
Yesterday motor and trans arrived
This morning I ordered a shifter relocation kit and my BRP mounts and mid length headers.
I'll post more pics when there's something worth looking at.
Old 03-06-2013, 12:11 PM
32deucecoupe's Avatar
32deucecoupe 32deucecoupe is offline
Thumbs up
Good progress, keep the pics coming.
Jeff
68' Camaro
56' Chevy PU- Sold
62 Nova project
Old 03-08-2013, 08:40 AM
Been busy, got the factory wiring sorted out, there's not much there!
Got the passenger side of the front section of the frame wire wheeled and spray bomb'd. I figure when I finally save up enough to get the body work all done I'll get the frame blasted and coated. For now this looks good up to about 2.5 ft, which is significantly better than the paint so I'll take it. I'd rather drive it this summer than wait till next year.
You can see that between the low light and cups of coffee I have very steady hands, but it gets the point across. Also visible, Pontiac blue from some hack shop that put cylinder head gaskets on for the previous owner. It was hiding under the grime. The next shot is actually in focus...
Started work on my gauge panel. I thought I'd be clever and sneak 3 3/8'' gauges into the stock holes. That won't work so I'm making a new panel out of cardboard...
I will be going with these:
http://www.summitracing.com/parts/nvu-67619-01
Old 03-14-2013, 08:14 AM
Updates; something that can only happen when there is progress. I've been busy working on the race Volvo with my team recently which has slowed my progress.
However, I did get my forward shift re-locator kit, since I am retaining the bench seat and using an F-body t56 I have to do it this route. Dismantling and re-building a t56 is pretty easy all things considered. I was fortunate in that mine had recently been gone through from what I could tell. Almost no visible wear on the synchros or blocker rings, the only point of concern I found was the 5-6 shift fork pad was broken at one end. I replaced the pads just in case.
Modifying the selector rail was another story...It took me one solid carbide bit and three cheap bits to get the hole for the rail pin drilled. Cutting and chamfering the rod seemed like a vacation by comparison.
In this next picture you get a sense of the awesome area I am doing this in, I need to build a real bench that can handle a trans! Luckily I was able to keep things clean and neatly organized despite what might pass for a sweatshop.
Then while I was having all this fun UPS showed up with my BRP motor mounts and crossmember. Hoping to get the motor and transmission test fit this weekend. Maybe if my wife is at the barn enough I can even get the rest of the firewall and frame cleaned up and painted.
Old 11-14-2014, 06:02 PM
Been a while, got busy working and stopped the updates. The car is a runner, I'm a father now and contemplating selling it. How times changes! Working on getting some pictures resized and up.
Old 11-14-2014, 06:07 PM
It's been too long since I posted too a forum, having a hard time uploading the pictures into the window.
EDIT: Nevermind, it obviously worked.
Old 11-14-2014, 06:15 PM
DBasher's Avatar
DBasher DBasher is offline
I saw Jason had posted something about this a few days ago, really a cool subtle build. I hope you end up keeping it!
Dan
