Old 03-05-2013, 02:32 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default Anyone Running LS or OBD II MUST SEE THIS!!!
This is a GREAT product! We checked them out at SEMA and these scanners are GREAT!!
SUPER affordable and easy to use. Stand alone touch screen data display, Iphone WIFI and Android Bluetooth!
http://www.plxdevices.com/product_info.php?id=GSSTWIFI
Email. Call or PM with the model numbers you want a quote on, we are offering free shipping in the 48 states and some discounts!
These systems work in ANY 1996 and newer vehicle or any OBD II equipped classic and they are NOT MARRIED to the vehicle you put them in meaning you can take the OBD II plug out, move it to another car and pull data, just like that! Great for road trips, track trips ect..
Data acquisition and several other sensors like Wide Band o2, EGT, Fluid temp, Vacuum/Boost
Take a look here at their site, there is SO MUCH info on these i didn't quite know how to post this ad!
Kiwi 2 Wifi is a plug and play automotive tool that connects to the onboard diagnostic port (OBDII / CAN). This tool communicates and retrieves information from your car's computer and wirelessly transmits to any iPhone, iPod Touch and iPad. It is compatible with 1996 and later vehicles and installs in seconds. The Kiwi 2 Wifi can efficiently monitor a vehicle's MPG, data log engine parameters, read/reset engine trouble codes and monitor real time engine performance. Simply connect your device to the Kiwi 2 Wifi through a wifi connection, and launch the compatible app of your choice to obtain vital information about your vehicle.
The Kiwi 2 Wifi includes several improvements over the first generation award winning Kiwi 1 Wifi. It now comes with a sleek new design and is 0.25 inches thinner. The cable length has been reduced from 6 feet to 3 feet, making for a cleaner permanent installation. It incorporates an elm327 compatible interface and it works with ISO9141, VPW, PWM, and CAN protocols.
The Kiwi 2 Wifi incorporates a new advanced power saving circuit, designed to shut off power to essential functions of the unit allowing the Kiwi 2 Wifi to be permanently installed in your vehicle without draining your vehicle's battery. After 5 minutes of inactivity, the Kiwi 2 Wifi automatically enters a low power sleep mode. To turn the unit back on, a simple press of the soft switch wakes the device back up.
The Kiwi 2 Wifi includes an 8 pin port on the back designed to be mated with the PLX iMFD Adapter. This allows you to connect high performance aftermarket sensors such as wideband air/fuel ratio, exhaust gas temperature, vacuum/boost, air intake temperature, fluid pressure and fluid temperature and view on your iOS mobile device. This solution is desired for applications where vehicles do not support certain sensors and/or the car's computer does not report them. With the PLX iMFD Adapter attached, the best of both worlds of fully plug and play OBD2 / CAN data as well as high performance aftermarket sensors can be obtained.
Features:
Depending on the application, the following features may be available:
Check Engine Diagnostics
Real-time Gauges
Fuel Efficiency and MPG
Engine Sensors
Customizable Dashboard
Real-time Dyno
Data Logging
GPS Track Mapping
Skid Pad
Video Recording and Data Overlay
iMFD Aftermarket Sensor Interface
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 03-05-2013, 05:42 PM
MaxHarvard's Avatar
I've had mine for almost 2 years now.
Works pretty well, kind of a PITA to get set up but otherwise works well.
