Old 03-06-2013, 03:57 AM
Moparigno Moparigno is offline
Default Brake line fittings
Hello,
I'm plumbing my brake lines and I need to get some good quality hardline fitting. I get the BrakeQuip catalog. It seems good quality stuff.
I see two different "seat types" for tube joiners: seat "X" and seat "Y".
I guess they refer to the type of flare you gonna use.
Do you know what seat type fits SAE 45 degree double flare ?
Paolo from Italy:
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383
'65 Shelby Cobra 427 Replica
Old 03-06-2013, 08:28 AM
Apogee Apogee is offline
In the image you posted, "X" is a 45 degree inverted flare and "Y" is a 45 degree bubble flare. Either is an effective option, however the inverted flare has been the standard for most muscle cars since their inception since that's what they came with from the factory.
Tobin
KORE3
www.kore3.com
Old 03-06-2013, 01:02 PM
Tobin
KORE3
thanks for the answer. I have a late model GM master cylinder (C6 Corvette). It should have (2x) M12x1.0 SAE metric inlets. Do you know if they require bubble flares as most of EU cars ?
Paolo from Italy:
Old 03-06-2013, 10:37 PM
The C6 Corvette MC actually has M12x1 metric inverted flare outlet ports, not bubble flares. FWIW, the C5 Corvette MC's were bubble flares, but only the '97 was (2x) M12x1, whereas the 98-04 were (1x) M12x1 and (1x) M12x1.5, the latter of which can be difficult to source suitable tube nuts.
Since you said you have the C6 master cylinder, a quick look inside the ports will confirm what they are
Tobin
KORE3
www.kore3.com
