Old 03-08-2013, 05:28 PM
tt69camaro tt69camaro is offline
Default BMR spring settling
Just wondered what people are seeing in their big block cars for spring settling? My car is sitting level now with the new springs installing but I would like to drop it a little more. If the springs will settle about an inch I would be happy with that and won't make any changes. Thanks
Old 04-07-2013, 05:14 AM
Jay Hilliard's Avatar
Springs may settle 1/4" after driving it. They will not settle 1" unless something was wrong with springs, which the springs would need to be removed anyway.
Jay
Old 04-07-2013, 07:27 AM
I just re-adjusted the ride height on my brother in laws 69 Camaro... it's not a BBC -- but is a blown SBC and the blower is H E A V Y.... and with dual carbs..
Just as Jay said -- I cranked the front coil overs up 1/4".... and raised the rear 1/2". The rears were adjusted more because the car was set up with empty fuel tank and no upholstery. When you add two people -- full upholstery and a tank of fuel... most of that goes on the rear (coil overs). So the added weight plus a minor amount of settling... and there ya have it!
Old 04-25-2013, 07:21 AM
It's been 1.5 months undriven and it hasn't dropped yet. I guess I will buy some taller ball joints. That should drop it another inch? Any recommendations on where to buy? Thanks
Old 04-27-2013, 06:36 AM
I already installed 1" drop springs on the car. I could return them and go with the 2" drop. After staring at pictures of the car a 1/2" would probably be just right. I think the springs will settle some also so the 2" drop springs may be too much. I was trying to help the front suspension geometry without spending big money on tubular control arms, although I may eventually do those in the future. I dont want to waste money on mistakes so if improving geometry means tubular control arms then I will have to wait until I can afford them. Do the tubular control arms change ride height? Will I need upper and lower control arms? This car is my wifes and not intended to be a corner carver. I'm just trying to improve handling while dropping it a little more.
